Rear hatch
Yes there is a way
To manually open the liftgate, do the following:
1. Remove the trim plug, located on the inside of
the liftgate near the center.
2. Locate the release lever on the latch.
The lever is located about three inches
(7.62 cm) behind the trim in the access hole.
3. Insert a tool into the access hole.
Push the release lever rearward.
4. The liftgate will unlatch when the lever is
pushed rearward. Push the liftgate to open.
5. Reinstall the trim plug.
Seeing as your salvaging skip #5
There's even a thread about it in the how-to tutorial forum!
https://www.chevyhhr.net/forums/how-...-release-8540/
I posted a picture in post #37
