Remote
Remote
2010 HHR SS. When purchased the vehicle it came with one fob. It only worked from the front bumper driver’s side to the driver’s side rear door. Installed a new battery. Same thing. I purchased a new factory fob and they programmed it. Same thing. My assumption is the antenna in the car has issues. True? Is there a part I can replace to improve the range of the fobs and its location? Thank you.
Mine works as you described. Up close, no problem when you push and release a button on the remote.
Now. What I found is if I'm any distance from the car (up to about 100 ft) then I have to hold the fob button down for an extended time. About a full 1.5 secs. seem to work for me.
Try that and see if it helps.
