remote start
Old 09-12-2024 | 10:55 AM
Eskimos's Avatar
remote start
Hello from Poland :)
Almost one year old thread, but still the most recent regarding remote start issues…
I just grounded the pink wire, turned ON the RS option in DIC, locked the car TWICE and then I pressed lock+panic buttons. The car started (yay!) and after 3-5 seconds it died and the only reaction to pressing lock+panic again is flashing the turn signals… I tried unlocking, locking twice again, starting the engine with the key - nothing. Disconnecting the battery repeats the situation - allows only to RS one time, for a few seconds, then the engine dies and i get only flashing turn signals.
Autel finds NO fault codes in any module…
Any ideas?
Old 09-12-2024 | 12:38 PM
Started new thread.
Did you ground the correct pink wire? Does the car already have the hood latch interlock from the factory? There would be wires going to the latch (not the impact sensor).
Did you read this thread https://www.chevyhhr.net/forums/how-...on-ap3-28551/?
If there is a hood latch interlock already installed there was no need to ground the wire. The factory interlock has 2 switches. one is "open" the other is ""not open"' one grounds when "open" the other grounds when "not open".
Old 09-12-2024 | 12:40 PM
Information in here might help you
https://www.chevyhhr.net/forums/how-...ion-ap3-28551/
Old 09-12-2024 | 12:41 PM
I’m not as fast typing anymore
It’s the purple wire not the pink wire.
Old 09-12-2024 | 12:59 PM
Eskimos's Avatar
Thanks for the replies.
I guess I grounded the correct pink wire as the car did start after doing so… Only once, OK, but it DID :)
There was only one pink wire at the lower blue-white connector, so I’m pretty sure it was the correct one.
Before grounding all I got was flashing turn signals.
There is no switch nor any electrical wiring at the hood latch.
There is a remote start option in the DIC and it is ON.
I’ve read all threads on remote start that were found by the search option and there was one post with similar issue - only one start and immediate going off and then only flashing, but there was no solution described.
My idea is maybe the ground on the nut holding the BCM is poor? Should I find some better ground point?
Old 09-12-2024 | 01:16 PM
Is this a 2008 year model ? Is it European or American equipped ?
The BCM is inside the passenger area. Did you mean somewhere else for the ground point ?
Old 09-12-2024 | 01:20 PM
The thread in the link I posted is for a 2008, in post #1 it is stated the purple wire. Perhaps yours is European wire harness
Old 09-12-2024 | 01:30 PM
Eskimos's Avatar
Yes, it is 2008, European (German market) model.
I used one of the bolts holding the BCM as a ground point, just under the connector with pink wire. Maybe I should search for better ground somewhere else?
Old 09-12-2024 | 01:38 PM
Yes like the ground in the rad cradle or the strut tower
Old 09-12-2024 | 02:48 PM
As Oldblue pointed out PURPLE not pink. Somewhere in that link there are pictures. Look at post #199 for a summary.
Does the speedo go to 120 or 200? 200 would be Euro.
