Remote Starter
Old 01-02-2008, 07:55 PM
andoll83's Avatar
Remote Starter
Why do my parking lights sometimes turn off when I remotely start, and sometimes they stay on? Also, sometimes I try and start it with the remote, but all is does is flash the parking lights.
andoll83 is offline
Old 01-02-2008, 07:59 PM
Firewatcher's Avatar
Join the club! Mine has been doing the same thing since new. I think there was a TSB on it, but I haven't really persued it. To me, it's only been a minor inconvenience....but it better start tomorrow because our high for the day is supposed to be around 10f.
Firewatcher is offline
Old 01-03-2008, 03:10 AM
Latrevion.washington's Avatar
Well Our Hhr Works Fine But I Know After U Use Your Remote Starter Twice Then U Have 2 Use Your Key, If U Try It A Third Time The Parking Lights Just Flash ,but After U Use You Key It Will Work Another 2 Times
Latrevion.washington is offline
Old 01-03-2008, 08:02 AM
PITTSBURGH HHR's Avatar
Chevy issued a service bulletin #07-08-47-002, "park lamps do not illuminate intermittently during a remote vehicle start." This only applies to the 2006 HHR model year. I had the problem of the parking lights not always coming on during a remote start. The service bulletin says to replace the BCM with part #15910666. The dealer replace mine and it has worked perfectly ever since.
PITTSBURGH HHR is offline
Old 01-03-2008, 09:40 AM
andoll83's Avatar
Does the dealer have access to the service bulletins? Is the repair covered by my extended warranty?
andoll83 is offline
Old 01-03-2008, 09:50 AM
ChevyMgr's Avatar
Yes and if it is a GOOD extended service contract, normally Yes.
ChevyMgr is offline
Old 01-03-2008, 10:14 AM
wingfeather's Avatar
I just bought a 2008 & so far haven't noticed this behavior. I know that doesn't solve your issue, but perhaps if they try to tell you it's "normal" you can ask them to show you normal behavior, using an '08...
wingfeather is offline
Old 01-03-2008, 10:49 AM
ChevyMgr's Avatar
The TSB number for 2006 HHR's is 07-08-47-002. If a 2007 or 2008 is doing the same thing the dealer should call Chevrolet Technical Assistance to see if this bulletin may apply. Definently don't accept that it is a "Normal" condition.
ChevyMgr is offline
Old 01-03-2008, 12:32 PM
Harpozep's Avatar
Our Remote starter does not start the car when it is cold out. It also disables the ability to try and restart it . I can go and manually start it, but the idea of the remote start is to get the car warmed up on cold days. It is useless, so time to see the dealer.
It is a 2006 model.
Had the same problem on my Honda. All cars suck. Just the ways of the world I guess. Well,Ok, our Raniier had no remote start problems......GO Buick!
Harpozep is offline
Old 01-03-2008, 04:00 PM
old motorhead's Avatar
10f. I'm coming down there.....only 2f when I got home at 3PM........but PEEWEE started right up He just loves the fresh air .....
old motorhead is offline
Quick Reply: Remote Starter
