Removal of 3rd Brake Light Cover
Howdy all! I'm trying to remove the plastic cover to get to the 3rd brake light so I can install my HHR Decal. I'm afraid of breaking the cover. Is there an easy way to remove it without damaging anything?
Thanks y'all!
Thanks y'all!
What Captain said. you need to pull quickly and firmly - prying slowly can sometimes bend the retainer clips. Give a firm yank. Start on one side, pull one clip, move to the other side, pull one clip, the other two should come off easy then.
Hope it helps,
Hope it helps,
Not unless you can flatten your fingers like Plastic Man. All you need to do is just unscrew the two bolts on each side, and then just let the light assembly hang down. It's not going to hurt the wiring or the fixture. Then just follow the directions for the decal, bolt the assembly back on and bing bang boom, you're done. If I can do it, anybody can.
