Removal of Interior Vinyl dress up coatings?
It's really hard to tell if it has removed the Armorall.
I might just give it another try and go over it twice instead of just once to see what those results show.
One thing is .. it does'nt seem to harm the Vinyl but then I'm not sure if I am even down to the Vinyl.
I would expect a fairly flat finish when the Armorall has been removed.
SF
The worst one I've ever tackled took three cleanings with Windex and Simple Green, even after that, the vinyl took a few weeks to finish "sucking up" what the cleaning couldn't completely remove.
Once you've reached the point of "that's all I can clean off" give things a dry rub with an old towel, while it won't be perfect initially, you'll have a natural looking finish after some time passes.
As a personal aside, anyone who Armor-All's the dash or other interior components, needs their fingers broken.
The downside with soap products is the neccessary rinsing process it takes after you wash.
I have a Shaklee biodegradable Industrial soap type cleaner that works wonders on non synthetic oils and greases but it will suds forever. The other thing is many of the areas to clean have openings and cracks that you might not want that cleaner to get into and just sit.
It sounds like a fairly simple (apply and wipe) process but there is more to it then that when the whole car has had Armor-All applied.
Thanks for the suggestion though...
SF
chevyorange
08-30-2009 11:52 AM
