Removing front door panels
They are mounted with clips and 2 screws nder the rubber cover in the pull handle portion. Be careful though, they are a two piece clip and if you break them (like I did) they are EXPENSIVE, my cost working at a dealer was over $5 a PIECE!!
There is also another screw in the center of the door handle cup. It's pretty easy to take off. After you have the three screws removed, there is a pin on the side near the door latch, push this in the release it. Then pull from the bottom the pop all the clips, then lift up. You need to undo the cable for the door handle and disconnect all the switches.
After you do the first one, less than 5 minutes a door.
