Removing side pillars
I know it has been discussed before, but I just want to be sure. I have the optional side curtain airbags. On the front pillar (with the tweeter) there is an oval plug that says 'air bag'. As I understand, it actually is just a cover for a bolt holding the panal in place.
If the ignition is off, does it reduce the risk of the bag deploying, or is it powered all of the time?
I am looking to run a power line from the sunroof controls to the fuse box.
There's only one screw holding the pillar. It looks like there's a lot of room between pillar and rolled-up side bag when I removed mine. I too had to run a wire from my rear view to the center console fuse box.
ufvj217
14
04-08-2020 04:00 PM
cj krause
05-25-2006 09:26 PM
