replace Upstream Oxigen sensor
Old 11-08-2021 | 12:10 PM
tomasorta's Avatar
I bought a Twist Socket Set 1/2 inch Drive Locking Wheel Nut Bolt Stud Extractor Removers Size 17mm 19mm 21mm 22mm from amazon, to see what happens. that plus candle plus heat, have to come off.
Old 11-08-2021 | 12:41 PM
Gearhead1's Avatar
the old aircooled vw wxhaust studs were the absolute worst. Problem was they got so hot the aluminum stuck to the steel. Tried PB blaster and everything else you can think off….paraffin works the best. Only exception is silicon oil
Trying the old school wax trick may have worked on the VW aluminum/metal stud removal. For this HHR problem it would probably be easier to just use a good penetrating oil. PB blaster or such should do the trick.
I would still try the heat it up method too.
Your biggest issue is getting a good "bite" on that old sensor that you buggered up.
Old 11-08-2021 | 05:20 PM
Maybe a picture or link to what this is?
Old 11-08-2021 | 06:04 PM
Gearhead1's Avatar
Let us know how it goes. As of yet, havent had to change one on 2011 we have so These other guys here probably know more about clearance and access involved in getting OX sensor removed
Old 11-09-2021 | 04:29 PM
tomasorta's Avatar
today I got the bolt remover with special theet to grap the bold nut from oxigen sensor,
1- if I cut the cable sensor the car is available to start for heat the manifold?, because this remover bolt looks like a regular socket so I will need to cut the cable to have access to the bold.
2-other think I can run the car without the metallic manifold shield ?
thanks so much
Old 11-09-2021 | 05:01 PM
Gearhead1's Avatar
Post pic of the tool you plan to use.
You should be able to run it to get it hot without the shield….if I were concerned about it…take it loose and use tie-wire to hold it in place so its easy to remove quickly before manifold cools down
QUOTE=tomasorta;917511]today I got the bolt remover with special theet to grap the bold nut from oxigen sensor,
thanks so much[/QUOTE]
Old 11-09-2021 | 05:48 PM
You can cut the sensor off just above the bolt piece, if you’re using the bolt extractor
Or this stud extraction device.
Old 11-09-2021 | 06:18 PM
Gearhead1's Avatar
Have you tried one like this?
Old 11-09-2021 | 11:13 PM
DON'T CUT THE CABLE, UNPLUG IT.
The engine will run without the sensor.
Old 11-10-2021 | 05:28 PM
tomasorta's Avatar
Yes old blue I used one of that size 22 mm and you know came off today very burn inside, was ease today I remove the black part of the windshield to have more space.but a details when I put in the exhaust the new one when I tried to plugin in the electrical socket in the car , not fit the electrical but fit in the manifold, I return to amazon where I bought and I will buy tomorrow in CAPS the upstream and downstream I will change both.but the extractor removal lung is the maximums for extract a bold bolt or nut.
