Replacement cluster
Replacement cluster
I found this on Amazon: http://************/59ny6o
About $136 with shipping. Checked their website and noticed they are in Flint, Mi., just down the road from me. I emailed them about will they install and how much. Got email back and for $150 for the cluster and install. For that price it isn't worth my efforts to try and do myself. Has anyone else got this yet? Reason I want it is that with shades on in the daytime I can hardly read the speedometer due to the black background with white numbers but the blue under the numbers sure makes it hard to read on 62 year old eys.
No cluster don't need reprograming as info is all in your computer. Cluster is like a computer monitor, it just displays the infomation.
Ratzilla I can see display fine at night with the gauges lit but in the daytime with my sunglasses on it is very hard to read.
The cluster has to have the correct mileage (yours), if that is what you meant by reprogrammed. If not it is against the law. The company who sells the should have that info about such procedures, if not its illegal to do so.
d-man is correct. Mileage data is stored in the cluster. I had my cluster replaced due to a scratch from the factory on the inside surface. The dealer was required to keep my car while GM overnighted the replacement cluster so the mileage could be programmed at the factory and when installed it would be correct.
I agreed with your sunglasses It hard read during the day. I am 58 and this hardest cluster to read on any car I have own and this only thing do not like about my HHR.US speedo does set your milage before get according their web site. My ? what about warrenty from Chevy will they void it or will they believe you set correct milage on the cluster
