Replacing headlight
Old 03-21-2013 | 12:04 AM
emd820's Avatar
Replacing headlight
Any short cut or trick to replace a headlight bulb, 2009 drivers side?
Old 03-21-2013 | 12:48 AM
Not really, turn wheels to right, pull inner fender pins & bolts, peel back inner fender, swap bulbs.
Careful not to touch the new bulb. Even oils from fingers can shorten bulb life.
I still wipe mine with alcohol last..
Old 03-21-2013 | 12:58 AM
Snoopy's Avatar
Sleepers got it, but also assure you remove the bulb gasket when you remove the bulb. They have a nasty habit of "sticking" in the housing. The new bulb will not fit, if this happens. And the new bulb comes with a new gasket in place.
goetylsd
Maintenance and Upkeep
59
06-19-2017 06:55 PM
Miltown SS
10-30-2013 11:56 AM
SteveMaine
10-13-2013 07:49 PM
hurst2001
08-08-2013 08:04 PM
zeevette
10-23-2010 10:00 AM
