Resetting OR Disabling Tire Pressure Monitors
Old 05-16-2008, 09:35 AM
goatcheez's Avatar
Just put new 18" aftermarket wheels on the LS and I'm getting a "Service TPM" message on the dash. Kinda figured this would happen. How to I disable this warning or at least reset the menu so I don't see it?? Anyone else dealt with this??
goatcheez
goatcheez is offline
Old 05-16-2008, 09:49 AM
cperez1217's Avatar
Did you put in the sensors in the new wheels? I di this on my cobalt. ANd you have to check your manual there is a combination you have to do with the remote and then let some air out of the tires and the senros will come online.
cperez1217 is offline
Old 05-16-2008, 10:02 AM
goatcheez's Avatar
No I did not put sensors in the new wheels. I may or may not. These
(the 18's) will just be my summer wheels so I don't know if I wanna drop the $$ on the sensors or not. I could really care less about TPM's I just want to either clear or disable the TPM warning if it's possible.
goatcheez
Old 05-16-2008, 04:39 PM
1Panel2NV's Avatar
As far as I know, you can't disable the warnings. I was only able last about two days before I put the sensors on.
1Panel2NV is offline
Old 05-16-2008, 05:27 PM
ChevyMgr's Avatar
If there is a way of doing it, GM isn't going to tell you, since this is now the law.
ChevyMgr is offline
hozer
03-26-2014 01:39 PM
09 HHR
10-17-2009 01:46 PM
SandyBeach
01-07-2007 11:27 AM
Lee3333
Tires & Wheels
19
08-19-2006 05:57 AM
Quick Reply: Resetting OR Disabling Tire Pressure Monitors
