Resonator rattle
Old 08-27-2024 | 10:32 AM
rwfnetworking's Avatar
Finally got my HHR up on a lift and discovered what was causing the rattle. When I added the header and new Catalytic Converter, I inadvertently lengthened the exhaust causing the tail end exhaust hanger to pull everything upwards, creating the rattle. So just need to shorten a bit and weld it back up. Last photo is where the muffler is making contact.
Robert
Old 08-27-2024 | 12:00 PM
Just touching the heat shield, may be just a tweak with a pry bar, and cure that rattling
Old 08-28-2024 | 06:28 PM
unknwn's Avatar
Mine had a heat shield over the top of the pipe as it rounded above the rear axle beam area.
I used some stainless scrubber pad between the pipe and sheet metal shield, and stainless wire to pull it tight in a couple spots, eliminated that rattle.
Old 08-29-2024 | 10:42 AM
WoodysMobile's Avatar
Necessity is the mother of invention.
Fasten 'er back in or pull it off and toss it either way
Git 'er done.
Simple is better bumper sticker should be issued.
Bonez
04-26-2020 11:48 PM
aurora_HHR
7
09-13-2013 11:49 PM
drse
03-16-2012 01:04 PM
spotty
02-24-2012 09:58 AM
Kevin Schneider
12-23-2011 07:18 PM
