Restoration of window switch trim to brand new look
I want to restore to brand new look the window switch trim inside the HHR. My idea is to buy the same paint color and spray, but I don't know what is the paint color. Any suggestion/information? By the way this is not my window switch trim I use this photo as an example. Mine is much less damaged, only a small scratch.
If you just shoot it with satin black paint no one‘s going to notice that it doesn’t match. Or maybe a matte silver. Or anything you like. With “Krylon” it’s very easy to get a nice finish but it isn’t that durable. You should probably prime with any “it sticks to plastic” paint you have lying around.
I like using
Last edited by PulpFriction; 07-31-2022 at 04:19 PM. Reason: Autocorrect turn my message into nonsense
I removed the switch bezel from my older HHR and I saw a sticker with the word Satin N on the back. Which I presume is for Satin Nickel color. So that would be the color I am looking for.
Meanwhile, I tried to repaint it with Rust-Oleum Pure gold for all surfaces. It did a good job but I decided it was not a perfect match for the interior of the vehicule. I also have at hand a satin silver spray paint which is close to the factory color but not exact match. I am trying it at the moment maybe I post picture later.
Satin Silver Metallic from Duplicolor. Did not sand anything just cleaned the bezel and sprayed a generous layer (actually multi layers all at once) just for testing purpose. I think it is very good but brighter than the other satin (nickel?) plastic inside the HHR.
