Retrofitting larger capacity battery in HHR
That's what I meant by you have to install it backwards, and then the cables were long enough.
And the spare tire cover went back on without contacting the terminals? The cover sits much lower in the area where your terminals are now.
Even so, I don't think I could've found a more ideally sized upgrade battery for the car if I had researched it. The fact that I bought that particular battery for my '02 4Runner when I didn't actually need to and then it just happens to drop in perfectly into my HHR and gives me a significant increase in battery capacity (and hopefully cold weather starting power) was pure serendipity/fluke.
I hope other HHR owners who want a larger capacity battery for their cars will find this post and go out and get the same battery for themselves. I'm not sure who makes those AGM batteries for Canadian Tire but I'm pretty sure it's a US company. I checked Exide's website and it doesn't appear to be them. Canadian Tire says the original manufacturer's part number is ELU34R. Here are all the specs so people outside of Canada can hopefully find the same battery under a different label:
Class/Group: 34R
CCA: 775
CA @ 0C (32 F): 890
Reserve Capacity Min @ 25A: 120
Ah Capacity (20 hr): 55
Length (in): 10.75
Width (in): 6.875
Height (in): 8
Battery Type: Top Post AGM Flat Plate
Canadian Tire Part No.: 010-2420
CT Link: MotoMaster Eliminator Ultra AGM Automotive Batteries | Canadian Tire
If you have to specify a vehicle to find the battery on a website you can use 1996 - 2002 (Gen 3) Toyota 4Runner. Not sure what other generations of 4Runners use.
Good specs, better than the Sears Diehard AGM (group 47) I have.
Dimensions:
Item Weight : 39 (lbs.)
Length : 9.625 (in.)
Width : 6.875 (in.)
Group Size: 47
Height : 7.5 (in.)
Power Ratings:
Cold Cranking Amps : 600 (CCA at 0 deg.F)
Reserve Capacity : 100 (RC)
This should help some people. Just to be clear, the posts are towards the front or the rear of the vehicle?
Thanks for posting this!
Dimensions:
Width : 6.875 (in.)
Group Size: 47
Height : 7.5 (in.)
Power Ratings:
I really don't think it's going to move. After tightening down the clamp on the side I tried very hard to get the battery to move and it didn't. I applied a lot of force trying to get it to budge and it didn't so I'm quite confident that it's not going to move just from driving around. I guess if I was super-cautious I could put some loctite on the clamp bolt threads but I'm not going to for now. I'll check it again in a few months to make sure the battery is still snug and maybe then I'll do it.
Note that the group is 34R not 34. I believe the R means reversed poles.
The tricky part will be to identify the same battery under a different label/brand that's available in the USA. I'm sure that battery is not exclusively made for Canadian Tire. I checked Exide's website and that battery did not come up in my search for a battery to fit an '02 4Runner. They make a flat plate AGM battery for the 4Runner but the specs are quite different. I think the AGM battery they showed me for the 4Runner is too tall.
I think I found where you can get the same battery in the USA. It's a Group 34R Sears Die Hard AGM Gold:
Compare these two batteries. They look identical to me:
Sears.com
I think this Interstate is even better. It's a better fit since it's slightly shorter and slightly longer and has more capacity. It's more costly though.
https://www.interstatebatteries.com/...ategoryid=true
The CT and Interstate batteries have 48 month warranties; the Sears Die Hard Gold only 36.
Sears.com
Lotsa of 34R battery’s in the states, Duralast, Interstate, Diehard, to name a few
https://www.google.ca/search?q=34r+a...&client=safari
