Im interested in putting 15" rims on so i can run a 75 series tire ,found a set off of a Buick century 2001 not sure about the bolt pattern or if the caliper will clear
I was able to get a deal on 205/60R16 instead of 215/55R16, tire dealer initially refused to do it but I pressed and they checked (w/ GM, I think they said) and it was fine, except they recommended 35 PSI all around.
These are a bit narrower, but we like the improvement in snow. The rolling diameter is virtually identical, a TINY bit larger.
