Roof rail measurement, quick favor?
Hey People! I don't have roof rails on my HHR SS (yet), and after several different searches on this board I couldn't find the info I need. So my question is this, can any of you measure the distance between the inside edges of the roof rails across the car and post them here? I need to know so I can make choices for aftermarket cross rails. Thanks in advance to anyone that can help out!
I guess I wasn't clear, I have the rails and templates, I haven't installed them yet. what I am looking for is the measurement from the inside of the installed rail on the passenger side, to the inside of the rail on the driver's side. the distance between the inside of the rails across the roof, not front to back.
I want to make sure when I'm ordering cross bars that they are wide enough to span the distance but not so long that they stick out over the sides of the car by too much.
Nope, the template is two seperate pieces of paper that show where the screw holes go. I could have eyeballed from their measurements but I figured better to be safe.
If I could have measured it myself acurately with the templates I would have. It would have given me the information I needed a week ago instead of today. Without the rails firmly bolted to the roof, I can't take into account variables like if the rails change position due to the roof curvature as opposed to sitting on the garage floor.
If talking out your A$$ about something that you have no knowledge about and suggesting that others are lazy when you are ignorant to the facts is your thing that's pretty pathetic, but if it turns your crank to be that way, more power to ya.
Whoa,chill out. I was in no way saying you were lazy. You my friend have interpreted my post the way you wanted to.
And if you say the templet "does not show the rails or in any way define their actual position in relation to each other", then how do you know where to mount them?
Oh never mind.
Oh never mind.
