Rough idle
Old 10-16-2021, 02:49 PM
SafetyDave's Avatar
Rough idle
Has anyone had a rough idle resolved after air intake hose was properly connected? My 09 had a rough idle so I thought it was the throttle body so I cleaned it, btw it was filthy. Still had rough idle. Ill be honest idle did the throttle body cleaning and didn't check anything else do to being on a time crunch. Today I had free time to check it out again. And noticed the air intake hose was completely disconnected from the engine bay wall. I did a cold start no rough idle just sat at 800 RPM. I then took it for a hour or so drive on a route I knew had a lot of stop lights that are timed poorly and speeds varied, still no rough idle when stopped at lights sat perfectly at 800 RPM. Could this simple hose reconnection be the solution?
Thanks in advance
Dave
SafetyDave is offline
Old 10-16-2021, 02:58 PM
Is the MAF plugged in correctly? If not everyone has.
Could be a ditry MAF if it is plugged. Use MAF cleaner from the auto parts store NOT some other spray.
donbrew is offline
Old 10-16-2021, 03:08 PM
So you had a rough idle, connected to air inlet hose properly, and now the engine doesn't idle rough anymore?
I'm guessing you mean 800 RPM, not 8000.
Continue to monitor it, if the idle stays fixed, call it a win!
RJ_RS_SS_350 is offline
Old 10-16-2021, 03:14 PM
It plausible the intake air hose or woolly worm cause an idle problem, if you cleaned that throttle body butterfly, did you spray both sides?
did you move the throttle plate manually?
Oldblue is offline
SafetyDave's Avatar
Yes meant 800 RPM. 8000 I definitely know there is a problem. Lol.
Old 10-16-2021, 03:15 PM
I’ll edit that for you.
Oldblue is offline
Old 10-16-2021, 03:16 PM
SafetyDave's Avatar
I may just carefully take it apart and use a cleaner on it. It won't hurt. I believe its the original hose but no leaks or anything. Original owner kept great records of all maintenance done to it.
Old 10-16-2021, 03:17 PM
SafetyDave's Avatar
Thank you
Old 10-16-2021, 03:21 PM
SafetyDave's Avatar
Yes when I cleaned the throttle body I cleaned both sides. And, no I didn't move the plate because I know they are prone to brake very easy.
Old 10-16-2021, 03:54 PM
The hose won't cause problems but the MAF sensor will. The hose is just a performance tweak, not essential.
The MAF is on the TB hose, the electrical thingy you have to disconnect to take the filter off.
donbrew is offline
Quick Reply: Rough idle
