Rough Ride
Old 05-05-2010, 12:26 AM
Is the rough ride in front or back ?
sleeper is offline
Old 05-05-2010, 08:17 PM
andoll83's Avatar
It seems to come from both, but if I had to pick I would say the back
andoll83 is offline
Old 05-05-2010, 10:30 PM
Some here have swapped rear coil springs to the cobalt SS/SC springs. It is a softer ride (I'm told).. & lowers the rear just more than 1"...
I used cobalt SS/TC rear springs. Also lowered the rear 1" to level on mine.
sleeper is offline
Old 05-05-2010, 10:35 PM
Jeda13's Avatar
I'd disagree about the Civic, I have a 2008 and it's as as smooth as butter. My HHr-SS is not rough but will rattle a little over rough roads. I put some padding on the license and that helps a bit. Have a qualified tech check out your suspension, you might have something wrong there and check out the heat shields while you're at it, my Escort rattled like a tin can until they fell off at 90K. Quiet after that.
Jim
Jeda13 is offline
MrAntDog
Maintenance and Upkeep
12-22-2014 08:01 PM
brossow
10
04-19-2014 11:39 AM
Eoj Nedraeb
05-16-2013 06:37 PM
Willie Ditz
11-22-2010 05:12 AM
T 20
05-27-2009 06:20 AM
Quick Reply: Rough Ride
