Round jack points for a floor jack
Old 04-15-2008 | 12:30 PM
GCarp's Avatar
Originally Posted by Goose
Also has me wondering why the exhaust is on the wrong side lol
Goose
Its just your point of view You have that god complex - Looking down on things. Change your point of view to laying on your back looking up and all is good.
Old 04-15-2008 | 12:48 PM
ChevyMgr's Avatar
Oh, It's a trick picture!
Old 04-15-2008 | 01:02 PM
solman98's Avatar
You know I just had mine on ramps this past Sat for an oil change. But If I remember corrently, the points I was using was a little more forward and inward of the stock jacking locations. I remember using the floor jack for the front and the scissor jack for the rear on the same side. It's been a while now, I'm just about due the next rotation. I'l have to double check it again. But I know nothing came close to bending and my floor jack has the standard round lift plate with the 4 raised points. I don't see how you would bend anything unless you just used the wrong spot to lift from. I know when had the nail in the tire from the roofers, I used my floor jack on the stock location on the right front to pull the tire. No issues at all. If I remember, I'll look tonight. I have to work on the wifes and will try not to forget.
Old 04-15-2008 | 02:53 PM
Snoopy's Avatar
Originally Posted by ChevyMgr
I think that picture is the United Kingdom version. You know how the have everything on the wrong side over there.
Looks like they either provide a different engine or they come standard with REAL dual converters and exhaust into one muffler. J/K
Old 04-15-2008 | 08:35 PM
GCarp's Avatar
Doh! missed that one.
Old 03-28-2009 | 10:28 AM
andoll83's Avatar
....isn't that diagram just looking at the bottom of the car?
Old 03-28-2009 | 10:38 AM
09 Panel's Avatar
Looks that way to me too
Look here for some floorjack adaptors to avoid damaging the bottom of the car.
http://www.protechproducts.net/jackpads.htm
Old 03-28-2009 | 03:40 PM
pg318's Avatar
We have the steering wheel on the right side, and drive on the left, the right is for peasants
Even us expat Brits get inline V engines in our HHRs, what do you get??
I'm not getting the comment about jacking the rear by the middle though, on mine there's the fuel tank, then the flex beam for the rear suspension, then the EGR kit, then the spare wheel well running back along the centerline, nothing that looks solid enough to lift on. I've a suspicion that the lifting advice, like the diagram, is generic information about RWD vehicles.
Old 03-28-2009 | 04:49 PM
Black Rose's Avatar
The question still remains....where are those round jack points?
Old 03-29-2009 | 12:15 PM
prod's Avatar
According to the pic, you jack it up on the running boards?
