RPM issue at idle
RPM issue at idle
I have been having an issue that the dealership can not find to fix. I have a 2007 2.4 that is having an issue with the rpm jumping at a light when I come to a stop. The car will come to a complete stop sit for a while and than the rpm will jump to 1500 -1800 rpm for some time and then go back down past 1000 rpms. Has anyone else had this problem.
I'd suspect the throttle body or the idle air control, I'd also take it someplace else since those folks aren't doing the job. A first stop you might think about is an Autozone or the equivalent where they can pull the code/codes and you can give that info to another dealership. And before I forget....Welcome and Greetings!
Franco Fanfuria
04-13-2011 11:30 PM
