?'s
Old 05-01-2020 | 08:26 PM
Bill VonSteuben's Avatar
?'s
I really appreciate this forum. Even digging through the archives I have a couple of questions.
How did the factory install the coolant? When I installed a replacement radiator, I filled the system with what I had drained, put most of the rest in the reservoir, and ran down the road a mile. Temp got up to 215 coming home so I shut down and coasted. Another time to got the reservoir empty, but the system still wasn't full. Topped it off and added some to the reservoir, now it seems stable. I think that is the recommended 3 burps. The factory must have had a simpler method.
Next subject:
Torque vs Torque-lite. Is Torque worth the $5 to use with a bluetooth OBD adapter and my android phone?
Thanks.
Bill
Old 05-01-2020 | 09:28 PM
The factory & Dealers use a Pump system, hook to one hose, load coolant (Dex-CooL) into the pump & the other hose to the collection machine. They pump it thru.
We can park on an incline to get the (front end) rad higher than the engine. Worst thing would be to trap air in the head. With rad higher the air tends to gravitate to the highest point.
Old 05-01-2020 | 09:31 PM
We recommend the burping method to ensure all the air comes out!
https://www.chevyhhr.net/forums/how-...-system-60614/
It’s very simple and you are halfway through the process!
Old 05-02-2020 | 09:08 AM
Torque lite is good enough for normal use. Good use for one of those old smart phones in the kitchen junk drawer.
Old 05-02-2020 | 09:16 AM
The factory used the small plug to allow air to escape from the head.
The bolt between the air box stud and the valve cover bolt, it is actually a plug in the cylinder head to the coolant passages
Old 05-02-2020 | 09:30 AM
Cat Man HHR's Avatar
Very well put about how the factory does it.
On a production line you don't have time to run an engine up to operating temp to "burp" the system.
Time is money.
Old 05-02-2020 | 09:33 PM
Same @ the stealerships.
JazzDad
09-14-2018 04:51 PM
Wirewoman
Maintenance and Upkeep
7
07-23-2017 04:43 PM
slonny
11-07-2016 07:30 AM
Zagohhr
01-08-2012 05:44 PM
RICK167448
05-04-2011 05:36 PM
