Saturn Aura Steering Wheel
Has anyone ever tried to use a Saturn Aura steering wheel, it appears its the same except for the airbag mount. which may be able to be retrofitted from factory hhr wheel. if not it also appears the radio controls are the same as hhr. I found one that's leather really cheap and.....
Any concerns or things to watch out for?
I just put on a leather wheel from a G6, same platform as the aura. It fit great, airbag fit, and the wiring worked as is. The horn plate was mounted and wired differently, meaning I had to use the switch bezels that came with it, but works fine.
Only problem with mine is the cruise and audio controls light up red.
![Embarrassment](https://www.chevyhhr.net/forums/images/smilies/redface.gif)
