Shimmy at 60mph???
Old 04-21-2006, 07:23 AM
SCOOT's Avatar
Arrow Shimmy at 60mph???
Interested if anyone else is experiencing the same issue I am....? I've got a 2LT with the (OEM) polished 17's and approx 1900miles on my HHR. I've always noticed a slight shimmy (or shake) when I approach the 55 - 60mph range.
Logically- took it to the dealer advising the front doesn't seem to pull one way or another (eliminating an alignment issue) and stating it only occured at a specific speed. Well - they pulled the wheels off and re-balanced stating they were 'all out of balance *a little*'! What exactly that means, I'm not sure- I always thought wheels were either IN balance or OUT... period!?
Well - turns out THAT wasn't the issue!!! Hell- I don't even think the dealer took the vehicle out for a test drive after balancing!?!?!
Curious if anyone else is, or has, experienced this issue with your HHR? I've wrenched on my fair share of vehicles over the years, and although I'm no mechanic- I'd like to think my dealer's NOT that cheap and incompetent (right ) !!!!!
SCOOT is offline
Old 04-21-2006, 07:26 AM
captain howdy's Avatar
Nope. No shaking with my HHR at well over 60.
captain howdy is offline
Old 04-21-2006, 07:29 AM
cj krause's Avatar
alignment or balance usually causes that
shaking when braking is warped rotors
good luck
cj krause is offline
Old 04-21-2006, 07:30 AM
wowzer's Avatar
Mine rides like a Buick at 70 mph.
wowzer is offline
Old 04-21-2006, 07:37 AM
hvrod's Avatar
The other possible item... it shouldn't because their brand new......
tie rod ends or ball joints...
hvrod is offline
Old 04-21-2006, 07:52 AM
1BadPig's Avatar
I think it's the Firestone tires. I noticed that shimmy when I hit around 60 MPH while the car is still warming up (a highway 1 mile from home). However after the tires got warm, the shimmy goes away.
1BadPig is offline
Old 04-21-2006, 08:03 AM
hvrod's Avatar
I got rid of those tires long ago..
After the first encounter of the rain grooves and those tires going squirrelly ..
hvrod is offline
Old 04-21-2006, 08:04 AM
ng8650's Avatar
No shimmy at 60 but I do get one when I first start moving. I'm guessing the infamous warped rotors or wheels need balanced. I should be getting new wheels this weekend so I'll see if it still doing it.
Ng
ng8650 is offline
Old 04-21-2006, 08:05 AM
ng8650's Avatar
Check your lugnut torque...When I did my springs and removed my wheels I noticed that the lugnuts were on barely above hand tight
Ng
ng8650 is offline
Old 04-21-2006, 08:24 AM
Clarke33's Avatar
Smooth as silk from 0-100, so far. Soon to be 0-100+
Clarke33 is offline
Quick Reply: Shimmy at 60mph???
