Should I clean this sludge or leave ot alone
Old 09-10-2022, 07:00 PM
advisual's Avatar
Hi,
Just bought his hhr which actually ran pretty smoothly after a hard start and coding P0016.
So I knew it needed a timing chain that I am in the process of replacing as I outlined in another thread - that had it's own issues.
But, I have seen differing opinions on this. Some say don't mess with it because it will cause issues down the line from chunks you don't remove. Others suggest taking a wire brush to it and cleaning as much as you can.
I only hesitate because that car would run very smooth but the amount of sludge this cat has on the top end concerns me.
Your suggestions are appreciated.
Thanks
advisual is offline
Old 09-10-2022, 09:28 PM
Wire brushes shed bristles, a loose piece of steel floating around is more dangerous that a loose bit of sludge. I'm not saying to not clean it, I'm saying don't use a wire brush.
Greybeard999 is offline
Old 09-11-2022, 07:53 AM
Old timey cure would be a quart of diesel in the oil far several hours running. Or, Sea Foam, Lucas oil etc. Read the labels, they are really diesel/aviation fuel.
donbrew is offline
Old 09-11-2022, 08:05 AM
Another old time treatment is Marvel’s mystery oil.
Oldblue is online now
Old 09-11-2022, 09:51 AM
Lonwane's Avatar
And change the filter often during the process
Lonwane is offline
Old 09-11-2022, 10:46 AM
geg
geg's Avatar
It looks excessively dirty, it needs to be washed. The upsetting thing is that this dirt is probably in the depths too. You won't come there with a rag - you need chemistry.
Flushing of the oil system, chemicals from carbon deposits on valves, etc.
And yes - a good filter
geg is offline
Old 09-11-2022, 01:11 PM
advisual's Avatar
Should I clean some of the excess with a rag while I have the cover off?
advisual is offline
Old 09-11-2022, 01:48 PM
Would not hurt.
donbrew is offline
Old 09-12-2022, 05:35 AM
geg
geg's Avatar
Soak a rag in gasoline, or white spirit, or alcohol, or brake fluid ... anything that can dissolve fats except Ferry.
And then a slow, progressive wiping of deposits.
geg is offline
Old 09-12-2022, 09:30 AM
greg8453's Avatar
Here's what you need to be concerned with, If you get pieces of gunk and or cleaning material such as scotch brite or pieces of metal brush and even one of these gets through and into an oil gallery you will spin a bearing.
That really isn't that bad. I would leave it alone.
greg8453 is offline
Quick Reply: Should I clean this sludge or leave ot alone
