are side rails just for appearance?
Old 12-26-2007 | 04:35 PM
melanieindica's Avatar
side rails
Are side rails for appearance only? Can they actually be used to strap down a fiberglass rooftop luggage carrier? This carrier doesn't require center rails. I don't have crossbars on my hhr. Help!!! I am traveling cross country on Sunday, and don't have time or extra cash to purchase factory crossbars. Any ideas?
Thank you so much for any help!
Melanieindica
Old 12-26-2007 | 04:56 PM
Size:  5.6 KB to the site!!! I do not have roof rails but many here do. I'm sure someone will answer before Sunday. Have a safe trip
Old 12-26-2007 | 04:58 PM
bigallis1's Avatar
Melanieindica
Welcome to the site.
Keep in mind that your total weight on the roof should not exceed 100lbs. (Chevy recommendation)
With that in mind, I would think you could put your luggage carrier on the roof as long as it sits between the rails and you can secure straps from the rails to the luggage carrier.
I would put something between the roof and the carrier to prevent paint damage.
If you are not comfortable securing without cross-rails, Thule makes universal crossbars that would work.
Others on this site have used them with satisfactory results.
Try doing a search under cross-rails, at the top of the page and it might link you to previous posts on this subject.
Good luck and let us know how you make out?
Also, post some pictures of your HHR when you get a chance.
Old 12-26-2007 | 05:06 PM
Thank you so much for your help. I feel some relief!!! I will post my results!
Melanieindica
Old 12-26-2007 | 05:10 PM
I don't think that would be good advice. With the weight placed on the crossbars, the load would be spread out across the majority of the roof, and not just in one spot.
Here are some pics of Karen's factory rails........
Old 12-26-2007 | 05:39 PM
Thank you, and I love the color of your car!! My main concern is if the side rails are sturdy enough to hold a luggage carrier in place. What is your opinion?
Thank you for your help! (And pics!!)
Melanieindica
Thank you!!!
Old 12-26-2007 | 11:20 PM
prod's Avatar
That is what the side rails are there for. They are supposed to take the weight though, not the roof panel between them. I can bet if you sat a 100lb weight in the middle of the roof it would dent. And arent the roof rails rated to 150lb?
If the luggage carrier is too narrow to sit on both side rails, you might be able to macgyver some homemade cross rails or a sheet of wood secure enough to hold it, but I wouldnt recommend it.
Old 12-27-2007 | 06:39 PM
SandyBeach's Avatar
Is this a hard plastic luggage carrier? If so, I believe Thule makes clips that will connect it directly to the side rails. Check out their website for information.
Old 12-29-2007 | 09:23 PM
prod's Avatar
Just checked my new '08 manual, it indeed says the roof rails can take 150lbs and not to load anything directly on the roof itself.
