Slow shifting transmission
When the temperature outside is in the 50's or lower my 2009 HHR is slow shifting into 4th (Overdrive). I have to drive it for 5 minutes or so to warm it up before it will kick in. Has anyone else experienced this problem? Or is it a problem? Maybe they are designed to work that way. My main concern is, does my HHR need servicing?
I am thinking that it has to be up to temp before it will go into lock up. I have a 06 with 68K and when I start off with eng. cold it will take up to 3-5 miles before it shifts and it has done this from the start.
