Sonic Welding
If you mean plastic, I have had luck in the past using a sharp razor blade going over the seam very carefully over and over again untill I have a space big enough to get a thin flat blade screwdriver in and try prying the pieces apart. Just need a little patience and a lot of time.
They were plastic welded I assume? What temperature did you use?
MEAN HHR
South Pacific
0
03-16-2007 10:59 AM
