sounds wierd ?
Old 05-19-2013, 09:15 AM
brown1243's Avatar
sounds wierd ?
My grandson used my o8 for a few days, he said it sounds like the motor is going faster than it should. the rpms are around 2200 at 60 mph but the motor does sound like it is going faster than it used to ANY suggestions what it could be?
brown1243 is offline
Old 05-19-2013, 09:28 AM
flex pipe?
donbrew is offline
Old 05-19-2013, 09:33 AM
HHR's run at approximately 2,250rpm at 60, so yours is right where it's supposed to be.
That's assuming you have an automatic, if you have a 5-speed I'm not sure what rpm they pull in top gear.
I'd check the exhaust, or have it checked, you may have a leak in the flex pipe from the exhaust manifold to the catalytic converter. When they let go, the engine note can become quite raucous.
If you have a manual trans, check for a slipping clutch.
843de is offline
Old 05-19-2013, 11:22 AM
PaperChaseHHR's Avatar
id say flex pipe is safe guess as well.. been through 2.. and an exhaust manifold (warranty mwahaha)
PaperChaseHHR is offline
Old 05-20-2013, 07:34 PM
brown1243's Avatar
it's an auto. will check flex pipe thanx!
Old 05-21-2013, 01:42 AM
If you check it when you first start it, more likely to see internal condensation weeping out of the flex-pipe at the crack. Good starting point anyhow.
sleeper is offline
Old 05-21-2013, 04:12 PM
jay loukakis's Avatar
If its the flex pipe you better drive with the windows down, and it will get worse, I bought my flex pipe from Rock Auto $35.99 plus shipping had it installed at Midas $90.00 its all good now, good luck.
jay loukakis is offline
Old 05-21-2013, 05:16 PM
2008LT's Avatar
Just went through this on my 08 LT, the Flex Pipe is covered under the 8-year/80K cat warranty. If that's what the problem is, better to just let your local Chevy service center take care of it.
2008LT is offline
Old 05-21-2013, 06:47 PM
I can definitely look into this situation for you. Could you please private message me your name, address, vehicle identification number (VIN), and current mileage? This will allow me to see that options you may have available.
Thank you kindly,
Jessica L.
Chevrolet Customer Care
ChevroletCustomerService is offline
Old 05-21-2013, 10:38 PM
Yup...
sleeper is offline
Quick Reply: sounds wierd ?
