Spare tire drain hole fix
Old 04-06-2021, 04:55 PM
Dgruber326's Avatar
Recently went to replace battery in wifes 06 hhr and found at least 3" of water so i knocked out a plug to drain it and now i am looking for something to seal it back up with. Is there maybe a rubber plug i can seal it up with?
Car sat for about a year so it is now being scrubbed top to bottom to get rid of the mildew.
Dgruber326 is offline
Old 04-06-2021, 05:07 PM
Try looking at the local Pick-a-Part. Measure the hole, go to a hardware store or auto parts store look through the parts bins. Gasp, go to a dealer parts department.
donbrew is offline
Old 04-06-2021, 06:41 PM
Dgruber326's Avatar
Wow just came for info to see if anyone had a quick fix, not for someone telling me to go to the parts department at chevy n spend 3 times the price for a piece of rubber but thanks for the reply!!!
Old 04-06-2021, 07:10 PM
There is no quick fix, other than finding the same sized plug you removed. If you drilled a hole and you didn’t mention the size of the hole, how can you expect us to know what to recommend.
My suggestion was going to be Flex Seal tape or putty , which would be more expensive, so I refrained.
Perhaps if you posted a photo of the opening you need to seal up, would help.
Oldblue is offline
Old 04-06-2021, 07:44 PM
Donbrew gave you 4 options. Not sure why you got bent out of shape about it.
But to the forums!
RJ_RS_SS_350 is offline
Old 04-06-2021, 07:53 PM
I bet the (gasp) dealer price is less than $5. You might find them in a variety pack at a place like Tractor Supply for more. I assumed that you you wouldn't ask the question if you didn't know that rubber plugs are a common item in the right kind of store.
You might look into ToastMasters to learn how to win friends and influence people. I am only mildly offended by your reaction.
donbrew is offline
Old 04-06-2021, 09:10 PM
Take the plug you knocked out & add some silicone to it & replace..
sleeper is offline
Old 04-07-2021, 10:10 AM
Silverfox's Avatar
X-2
You want an easy cheap fix ....That's It !!
NEXT ......
Silverfox is offline
Old 04-07-2021, 11:32 AM
geg
geg's Avatar
Что ж, если вы ищете дешевую, но технологичную и долговечную ...
Есть такая игрушка - полиморфный пластик. Дети используют его для творчества и развлечения. Взрослые иногда обращаются к этому, чтобы решить неотложные проблемы, например, сделать пробку для быстрого слива.
Я уверен, что в США это продается где-нибудь в магазине игрушек или в отделе рукоделия вместе с вышивкой и фигурками для сборки.
Вот видео, для работы нужен только чайник с кипятком.
Сливную пробку любого размера и конфигурации можно изготовить за пару минут.
geg is offline
Old 04-08-2021, 05:33 PM
Dgruber326's Avatar
Its fixed
Its fixed. Plug from advance auto
Quick Reply: Spare tire drain hole fix
