splash guards w/o HHR logo
I am new to my HHR, if I just buy the splash guards with the bowtie logo, I need to drill holes on it before install. is that correct? And there is no such hassle if I buy the ones with HHR logo.
Thanks.
Thanks.
If you get to OEM guards. youll have a perfect fit with no drilling. I got mine from and know another member did also at this site. http://chevroletpartspeople.com/Sear...+Splash+Guards
Add one for the factory molded ones. Great fit and here is a tip:
If you go with the GM ones, pick up another set of the plastic push in fender liner fasteners. When you remove the old ones, they are not re-useable. The new ones will work great to hold on your new flaps and take just a sec to install. I didnt drill the bottom hole and didnt use that one and they work just fine. Also, the HHR logo is the same color as the flap, hardly noticeable.
Yeah, but that is so boring. Got to add a little flair!
