Spots on Glass
Spots on Glass
After washing my HHR, I have spots on the glass. I only use the self-wash part of the car wash here in town, and it has a (or suppose to) filter system. Problem, still have spot on the glass, and shows more on the tint. I thought of buying the Mr. Clean system for home use, has anyone tried this. If so, how is it.
Also, I remember years ago there was a glass wax did did wonders, anyone remember it, or could recommend something?
On the MR.Clean system, I have it but never use it. It does not have enough pressure during the wash setting for my liking and you still need to wash with your hands to remove that fine film of dirt, the results of the filtered water and fine mist in the final rinse setting is awesome. It really does dry itself and leaves no spots ( of course don't try it in the sun). I found that it takes just as long if not longer to use the Mr. clean kit compared to towel drying but there is less physical work, you will need to do some light touch up drying.
As for the water spots on your glass, most auto parts store will have some type of auto glass stripper. I have used No Touch Auto Glass Stripper, and Glass Science Glass Scrub, they both work well with the Glass Scrub being the best of the two. Niether are very good for your paint but will not do damage unless rubbed on the paint or left on it for a long period of time.
I hope this helps.
I hope this helps.
thanks for the info
I hope this helps.
I hope this helps.
![Cool](https://www.chevyhhr.net/forums/images/icons/icon6.gif)
I would suggest applying rain-x...I have been using rain-x since my first car when I was 16, my dad & grandfather use it religiously, and it is the first thing I do whenever I get a new car. I can't live without it.
I do not find the microfibre any good for drying. They do not absorb. If I use a good absorbent product and dry it out of direct sun, no spots. A dry microfibre towel would work to remove any spots after drying I would think.
