Squealing grommet on steering shaft
Old 08-14-2024 | 07:57 PM
autahciscoguy's Avatar
I replaced my intermediate steering shaft a while back with the Dorman replacement. When it started getting hot this year, it started squealing when I turn the wheel. At first I was able to use some silicone lubricant to get it to settle, but now that's not working. Any ideas what else I could try?
Old 08-14-2024 | 11:00 PM
What gasket? The usual squeak is the bearings at the top of the struts, maybe the clock spring or the turn signal cancel ring.
Old 08-14-2024 | 11:18 PM
The link in my signature may help diagnose the sound.
Old 08-15-2024 | 08:59 AM
As far as I can tell getting under the dash and listening, it's coming from the grommet that goes thru the firewall.
Old 08-15-2024 | 09:30 AM
Pop out the grommet and slide it up and down into white lithium grease. Then reinstall into the firewall, ensuring it’s fully seated.
Old 08-16-2024 | 07:19 PM
Makes sense. I was hoping someone had a magic trick where I didn't have to pull the damn thing out again. Such a pain in the rear to get it back in. 🤣
Old 08-19-2024 | 05:06 PM
PittKrewBowling's Avatar
LOL mine does the same thing. I'll just have to live with that little farting noise when I make tight turns. That rubber piece is a ROYAL PAIN to deal with.
Old 08-19-2024 | 06:18 PM
You could use spray white lithium grease stick the little red straw in there and squirt!
Riktar
07-20-2024 06:05 PM
cierra2001
07-10-2021 06:15 PM
serch826
10-22-2017 07:02 PM
webpirate
01-08-2016 02:42 AM
1970judge
11-14-2011 08:15 PM
