SS Userbars
A long time hot rodder and car lover here... and as I've stated before... I have put 4bbl carbs in place of 2bbls.... new manifolds, cams, ignitions and other "cheap" mods to my Camaros, Impalas, etc over the years.
Nothing has come close to instantly working and being appealing as the TT sway bar. Just driving 5MPH the car's steering wheel is razor sharp and a couple times I've pressed it in the dry to where even the 50 series rubber was getting scuffed on the sidewalls without losing an inch of space sliding.
You do not need to drive like a mad man to appreciate the control and the security of being able to just out handle the next car in an emergency.
I see ZERO negative to this modification. I live in Seattle where it rains... if you're dumb enough to push it hard on a cloverleaf in the rain even in an Audi Quattro... you're determined to push it...
Just my two cents!
Just my two cents!
SHEET!
My two cents are worthless!!!
Since you quoted it, I went ahead and deleted it so future internetters. :)
Moving to the correct area...
Last edited by chevyorange; 11-08-2008 at 01:10 AM. Reason: Originally posted in wrong thread.
