SS Userbars
Old 11-06-2008, 03:50 AM
IgottaWoody's Avatar
SS Userbars
Don't know if this is the right thread but permissable to move as needed
When will we see some userbars for the SS..and panels..?
IgottaWoody is offline
Old 11-08-2008, 01:06 AM
halfpanel08's Avatar
Originally Posted by chevyorange
A long time hot rodder and car lover here... and as I've stated before... I have put 4bbl carbs in place of 2bbls.... new manifolds, cams, ignitions and other "cheap" mods to my Camaros, Impalas, etc over the years.
Nothing has come close to instantly working and being appealing as the TT sway bar. Just driving 5MPH the car's steering wheel is razor sharp and a couple times I've pressed it in the dry to where even the 50 series rubber was getting scuffed on the sidewalls without losing an inch of space sliding.
You do not need to drive like a mad man to appreciate the control and the security of being able to just out handle the next car in an emergency.
I see ZERO negative to this modification. I live in Seattle where it rains... if you're dumb enough to push it hard on a cloverleaf in the rain even in an Audi Quattro... you're determined to push it...
Just my two cents!
i think you posted this in the wrong thread
halfpanel08 is offline
Old 11-08-2008, 01:08 AM
chevyorange's Avatar
SHEET!
My two cents are worthless!!!
Since you quoted it, I went ahead and deleted it so future internetters. :)
Moving to the correct area...
Last edited by chevyorange; 11-08-2008 at 01:10 AM. Reason: Originally posted in wrong thread.
chevyorange is offline
Old 11-08-2008, 01:09 AM
ya, copy and paste it.. over to the sway bar thread.. there is two threads going about TTR sway bar..
just tryin to help a brotha out
Old 11-08-2008, 01:25 AM
SSCasey's Avatar
I made the user bar below. If anyone wants, they can use it.
SSCasey is offline
Old 11-08-2008, 02:38 AM
Yonash's Avatar
can you make a black one? i suck with photoshop...
Yonash is offline
Old 11-08-2008, 05:30 PM
Your the man!!:twothumbs (now we need colors)
Old 11-09-2008, 10:48 AM
SSROADSTER's Avatar
how do you????
how do you get the userbars in your sig?????thanks.....
SSROADSTER is offline
Old 11-09-2008, 01:43 PM
copy n paste.. go to your inbox , then on the left there will be edit signature..
Old 11-09-2008, 09:07 PM
SSROADSTER's Avatar
thanks....but not working for me... going to get some sleep try tomorrow
Quick Reply: SS Userbars
