Steering Wheel Emblem
You can pry it off, carefully, with a very small screwdriver. You will definately want to put something else there or get a replacement because there are slots if i recall which are very visible once its off. It is also domed under it so it make it difficult to replace it with something flat.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Had a dent in mine too, took mine off... Bad idea, it is really flimsy. I did more damage taking the damn thing off.
Called a local dealer, its a part of the air bag and does NOT come separately. DAMN! So now, I am looking for a replacement something to put in there. Its got to be very close in circumference to the original to cover the slots.
Anyone have suggestions???
HELP!
Groovielou
HELP!
Groovielou
