Steering Wheel Radio Switch
Old 12-21-2021, 05:10 PM
New to me HHR's Avatar
I have PN 25824388 radio switch that I would like to add the my 2010 HHR non-SS. Will this part number work with the correct wire harness?
I have the cover for this switch.
Thanks.
New to me HHR is offline
Old 12-21-2021, 05:55 PM
This is the steering wheel control buttons.
What is in the steering wheel now?
RJ_RS_SS_350 is offline
Old 12-21-2021, 06:11 PM
I have the LS model with only the cruise control. I want to add the radio controls so I purchased an SS wheel complete with the controls. I can use the SS leather wrapped wheel or transfer the switches over to the LS wheel.
Old 12-21-2021, 06:25 PM
Should be able to just switch steering wheels. If somet6hing doesn't work take a look at the wire colors in the connectors. Nothing will release magic smoke if it is wrong.
donbrew is offline
Old 12-21-2021, 06:35 PM
I will verify the color code with the cruise control since that should line up with both wire harnesses.
Will the airbag from the base model fit the SS wheel since I don't the original from the SS wheel?
Old 12-21-2021, 06:37 PM
It should. The connector is the same.
donbrew is offline
Old 12-21-2021, 06:42 PM
I assume the wheel can only be removed with a puller?
Old 12-21-2021, 07:33 PM
Mine came of with a bit of persuasion. Be sure to note the mark on the wheel to line up on the keyway.
donbrew is offline
Old 12-21-2021, 07:44 PM
Was that with a puller?
Old 12-21-2021, 07:52 PM
no.
donbrew is offline
Quick Reply: Steering Wheel Radio Switch
