Stock Fog Light Size
Does anyone know the actual size of the stock fogs? Is there much gap around them? I know about the electrics and reprograming the BCM and all of that so I'm just concerened with size mostly.
The lens is 4 7/8".......Then there is about 1/8" gap between the lens and the rest of the fog housing. Then there isn't any gap from the housing to the bumper fascia....Hope this helps.......Regards
P.S. Make sure that your BCM can be re-programmed. Mine was locked and couldn't be re-programmed and would have required buying a new one (BCM) and then having that one programmed.....Dealer Quote was $422.00......lol!!!........Regards
I am planing on using after market lights and most likely wiring them direct omiting the BCM. I thought it may be possible to buy and use the OEM switch but I have not looked at that close enough to see if it can be done considering that that is a momentary switch. Keeping the stock look would be nice.
If you want to make things real easy, (my suggestion) simply use an aftermarket rocker switch or toggle mounted in a convienent location.... Good Luck with your project.........Regards
You could use the factory monentary switch to trigger a self latching relay circuit. Just take the +12v output and jumper it back to the + coil side. One push will energize it and latch it so it would stay on until you shut the car off.
Another option would be to get a "Flip Flop" relay that would toggle both on and off with each push of the the monmentary switch or you could build your own if you are handy with electronics.
http://www.attr.com/alarm/a4757.htm
Regards..........
