Stumbling at start? Quick help, thanks.
Old 05-24-2013 | 08:42 PM
SwaintaN's Avatar
Ok the HHR LS 2.2 is all of a sudden stumbling at start. Itll do it once or twice then rest of day is fine. Mainly in the morning after sitting over night.
What should I start to check? Wanting to fix it before it causes real problems.
Old 05-24-2013 | 09:11 PM
If you mean seems to miss once immediately after starting. Mine does that occasionally. I just scratch my head and move on. It's way down my worry list.
Most will say: dirty gas, clogged fuel filter/bad fuel pump (same fix), maybe a spark plug gap off, dirty throttle body or just because.
Old 05-24-2013 | 09:18 PM
badassbowtie's Avatar
first thing I would do is dump some octane booster in it....or fill with premium. it will help if you got a bad batch of gas..
on a more serious note, if you are losing fuel pressure, it may stumble and eventually the fuel pump could be going. but not likely if you dont have high mileage on your car(like 70,000+)
Old 05-24-2013 | 09:34 PM
A quick and dirty way to check on the fuel pump's health is to enlist the help of your wife/child/neighbor.
Have them turn the ignition to "Run" without starting the engine while you listen at the fuel filler(gas cap off), you should hear the pump emitting a steady hum. If you hear a fluttering hum, grinding noises, or a screech...your pump is on the way out.
It does sound like you have low fuel pressure at initial start up.
Old 05-24-2013 | 09:48 PM
SwaintaN's Avatar
Ok done list:
Just installed new plugs and boot. With premium plugs, proper gap, i did them.
Oil n Filter Changed.
THEN took it to Shell and got Prem Gas with Octane Booster
Now sitting at 1/8th tank it started this sputter at start crap where you have to slam the gas petal to get it to stay running.
Also 209k miles. Not sure what was all done because its a freebie from wifes parents.
Old 05-24-2013 | 10:01 PM
Sounding like pump or worse.
Old 05-24-2013 | 10:02 PM
SwaintaN's Avatar
or worse?
Old 05-24-2013 | 10:11 PM
Originally Posted by SwaintaN
or worse?
compression I would assume donbrew meant...but I think your looking at fuel pump or fuel filter issues. It is a all in one unit(pump, filter, float sensor) if Im not mistaken. You have enough miles for 2 fuel pump replacements
Old 05-24-2013 | 10:17 PM
At 209K, lots of potential internal wear. Valves, rings, carbon, timing chain, cam sprockets etc. You may need a pro to diagnose. Compression test, leakdown test, visual inspection that sort of thing.
Just about anything else should throw a code.
Free is seldom cheap!
Old 05-24-2013 | 10:33 PM
IgottaWoody's Avatar
1/4 tank? 209k miles? Sounds like crap is in the tank, and at , 1/4 tank (4gal) not enough fuel dilution to offset it. Water? Filter sock dirty? Try some good system cleaner and see what happens. If it is only doing it at 1/4 or below, I'd go this route first.
Quick Reply: Stumbling at start? Quick help, thanks.
