Suggestions…
Old 07-19-2021 | 07:51 AM
Out the grommet in the spare tire well by the battery?
Old 07-19-2021 | 08:16 AM
Gearhead1's Avatar
is there one there? If so, cool. That should work. Thanks
Old 07-19-2021 | 08:22 AM
Hmm. I guess post #6 saying there are "several back there" .....was ignored.
I'm out.
Old 07-19-2021 | 09:35 AM
Gearhead1's Avatar
I'm out.
Sorry, missed that one. Thanks for your imput
Old 07-19-2021 | 10:15 AM
Is the HHR the toad or the towing? I don't know why you would need to run wires all over the place. The tail light wiring is easily accessible either in the rear or at the BCM. And, as I pointed out earlier there are wireless options that cost less than wire; might need to add a layer of tin foil to your hat.
Old 07-19-2021 | 10:38 AM
Gearhead1's Avatar
I will be towing the HHR behind Motorhomes.
Old 07-19-2021 | 12:42 PM
Why do you want to run wires to the tail lights? All of the wires are available at the BCM. And the wireless options.
Old 07-19-2021 | 02:22 PM
Wireless kits are expensive!
Old 07-19-2021 | 05:39 PM
If you consider $50 expensive.
https://www.ebay.com/itm/17483501853...8AAOSwHF5g1mll
Old 07-19-2021 | 07:15 PM
Donbrew , I’m up here in Canada , cheapest one I found.
https://www.princessauto.com/led-wir...t/PA0008814964
