Sun Roof
Old 11-04-2020 | 04:11 PM
Bonez's Avatar
Sun Roof
Is there an adjustment to tighten up the sunroof when it closes? I dont have any leaks BUT hellachious wind noise. It seems the forward part needs to pull down harder as I can push on it lightly and it flexs quite a bit downwards still, Driving on the highway sounds like a jet engine on the roof. If you open the interior cover its loud as hell, still loud with it closed. Ive never had a sunroof sound like this.... just getting annoyed with it.
Old 11-04-2020 | 07:20 PM
PulpFriction's Avatar
Following this because I have a sunroof that doesn’t work, sticks up a tiny bit, but doesn’t leak that I know of. I have no idea what the problem is and am afraid to touch it until the weather improves because my garage has no heat, lol.
Old 11-04-2020 | 07:24 PM
You might check the "how-to" area; there are a few different fixes.
Or, a search I found at the bottom of this page, in the "related topics": https://www.google.ca/search?q=hhr+s...iw=375&bih=626
Old 11-04-2020 | 07:47 PM
There’s a thread about adjusting the sunroof panel , I just can’t find it, I’m in a meeting now till 11:00.
Old 11-04-2020 | 09:57 PM
Could it be in the link I posted from your post below in the "related topics"?
Old 11-04-2020 | 10:06 PM
Bonez's Avatar
found this.
Try this:
Old 12-06-2020 | 06:46 AM
rorr's Avatar
If your sunroof operates just fine, but needs adjustment, there is a way to lower and raise the glass. Remove the 2 side plastic bellows and it will reveal the glass mounting screws. GM says to put the front flush to 1mm below the roof surface, and the rear at flush to 1mm above the roof surface.
i can print the procedure and send it if need be.
Robert
JOHNNYO
Maintenance and Upkeep
11-16-2022 12:19 PM
denny
07-01-2010 09:19 PM
dfdtruck22
04-10-2010 11:22 PM
andoll83
05-21-2009 10:56 AM
pjtaxi
01-13-2006 10:03 PM
