sun roof adjustment
sun roof adjustment
How do I adjust the rear of the sunroof up to seal tighter? I hate the constant wind noise while on the highway. Its the same all along the back, just needs to raise up a tad more.
In here post #92 has a link to the glass adjustment
https://www.chevyhhr.net/forums/how-...-11629/page10/
I just adjusted my sunroof over the weekend. He is how you adjust the sunroof. Put the sunroof in the tilted open position. You will see on each side of the sunroof black folded plastic, behind the plastic is the adjustment screws. Carefully pull the black folded plastic off the sunroof. Once the black plastic is removed from the glass part of the sunroof you will see two adjustment screws. I believe they are T-25 or T-27 Torx (I can't remember). Make minor adjustments to the sunroof. If you over-adjust the sunroof and try to close it, it will start to close then get caught, and then start to slide back. I have heard that Shinu Etsu Silicone Grease works wonders on plastic seals, Honda has sworn by it for decades.
