Sure is a low hanging nose on this critter
Old 08-27-2019 | 07:22 PM
Originally Posted by solman98
I always used my Rhino ramps on mine. I wasn't lowered and never had a problem. Granted the is the back, but used the same ramps on the front.
Yup those work... even with mine lowered, they work just fine.
Old 08-27-2019 | 08:01 PM
I have those for a quick access underneath of my Zero Turn mower, to give the deck a quick clean out..
Old 08-28-2019 | 12:25 AM
geg's Avatar
geg
I do not know if you are using an object such as a "tire chamber" in the USA. Probably there.
If there is, buy it. Find one that is from a heavy truck, but not a very large diameter.
Put it under the car in front, under the subframe. Put strong plywood between the chamber and the subframe.
Pump up - this will lift the nose of the car and you can use the jack.
you can still simply hit the chamber with a wheel, and then Pump up the chamber
but so you only lift one side of the car
even a plastic bottle can be useful
in general, experiment - it is very exciting. But take precautions.
PS/ This will be useful to you in the future. The bus chamber is a multifunctional thing. You can pick up the car even if it drowned in the river, children skating from a snowy mountain in winter or playing in a summer pool. The perfect tool and toy "in one bottle" at a ridiculous price.
Old 08-28-2019 | 01:45 AM
wren's Avatar
Originally Posted by Doc brown
Why would you need a second floor jack? I just use one even if I need both wheels off the ground. Jack on side up, as said from the bump just behind the rear LCA bolt. Slide a jack stand in, move to the other side.
Over the years I've found a few cars that flex a bit too much if lifted high from a single point. Get door bind or other effects.
I figure there's no harm in taking a little extra care. Respect the vehicle and it gets cooperative.
Wren
Old 08-30-2019 | 03:16 PM
Doc brown's Avatar
Wren
Never experienced that myself. But you're right, no harm. I'm just saying you don't need two jacks for this car.
Old 08-30-2019 | 03:24 PM
2manyvans's Avatar
I have Rhino ramps and have to use 2x6's so the lower lip won't scrape on the ramps like Sleeper suggested . john
Old 08-30-2019 | 05:04 PM
Blue_SS's Avatar
I use a hockey puck on my floor jack. Yeah, I got the idea from a Canadian - not here - but it works beautifully. Pucks are cheap. I always jacked the SS up one side at a time that way, with stands. The front was way too low.
Old 08-30-2019 | 05:35 PM
Are you sure , it wasn’t Don Rickles? or Mr Potatohead?
Old 08-30-2019 | 08:41 PM
John- That does work well.....
Blue_SS- I have a short 2x4 that fits my jack saddle cup, & a 4x4 that can do the same, just depends on what I'm lifting.. For anyone who just wants to just buy, Northern Tool / Walmart / Jegs etc have them as well.
HHRnovice
09-17-2019 07:58 PM
Goose
12-03-2014 10:00 PM
speedwagen
Maintenance and Upkeep
23
05-29-2014 03:26 PM
08blackHHRSS
Tires & Wheels
26
07-23-2009 06:49 PM
Goose
04-14-2008 05:54 PM
Quick Reply: Sure is a low hanging nose on this critter
