Tach wiring Question
I want to install an after market tach (Sun) but it runs off the coil. Since each cylinder has it's own coil, that won't do. Can anyone tell me anything about the factory tach wiring? Can I intercept the factory tach wire and use that? Any other ways of doing this?
Thanks
Cliff
Thanks
Cliff
What I can say is you need to get a wiring diagram for the PCM and know what wire is used for the tach signal.
On LS1's we connect right from the PCM.
List the actual tach your using please.
