Temp. Gauge and A/C
Temp. Gauge and A/C
Hello, newbie here , my name is Tillman AKA Frank. I have a 2008 HHR and have a prob. Tha A/C works fine and all of a sudden the temp. Gauge shuts down.....0... and the A/C shuts off until the temp gauge is working again. Sometimes for a few MLS and then sometimes for days at a time. Would this be a replacement of the sensor or the themastat.
Thermostat... very rare that the sensor is the problem. I would suspect sensor wiring before the actual unit itself. Those symptoms are actually showing you that the sensor reported a fault to the ECU.
Make sure you use the proper AC-Delco thermostat or the same thing is going to happen.
