Temp. Gauge and A/C
Old 07-04-2018, 09:05 AM
tileman2692's Avatar
Temp. Gauge and A/C
Hello, newbie here , my name is Tillman AKA Frank. I have a 2008 HHR and have a prob. Tha A/C works fine and all of a sudden the temp. Gauge shuts down.....0... and the A/C shuts off until the temp gauge is working again. Sometimes for a few MLS and then sometimes for days at a time. Would this be a replacement of the sensor or the themastat.
tileman2692 is offline
Old 07-04-2018, 09:19 AM
Thermostat... very rare that the sensor is the problem. I would suspect sensor wiring before the actual unit itself. Those symptoms are actually showing you that the sensor reported a fault to the ECU.
Make sure you use the proper AC-Delco thermostat or the same thing is going to happen.
Greybeard999 is offline
Old 07-04-2018, 09:21 AM
t-stat first. AC/Delco 131-158 ONLY
If that doesn't fix it get a sensor.
BTW, the life time of DexCool is 5yr or 100,000 miles, whichever comes first; most likely you are due.
donbrew is offline
Old 07-04-2018, 09:38 AM
Thank you so much, leaving for S.C. ( with different vehicle) so won't get to replace it till I get back on the 16th. Will get back for my reply
Old 07-19-2018, 01:42 PM
What a *****....got it in and no change engine light comes up, .......flat line and no a/c. Where is the sensor
Old 07-19-2018, 02:01 PM
#706 in this diagram, right near the thermostat. What thermostat did you use? What is the code for the Check Engine Light(CEL)? Did you change the coolant?
RJ_RS_SS_350 is offline
Old 07-19-2018, 02:14 PM
Did you burp the coolant?
Oldblue is offline
Old 07-19-2018, 03:26 PM
Burp yes, went back down and installed a new temp. Sensor. That did the trick
Old 07-19-2018, 03:28 PM
A/C Del.131/158 as suggested. Thanks folks
Old 07-19-2018, 08:26 PM
Fixed , awesome! You did change the Dexcool, didn’t you.
Oldblue is offline
Quick Reply: Temp. Gauge and A/C
