Temp Sensor Location
Does anybody know where the actual sensor is located that measures the outside air temp, the temp that is displayed on the DIC menu selection along with the total miles driven?
Originally Posted by cschhr06
i might be wrong but i beleive its the little bubble right in the middle of your dash up against the windshield...
That's the light sensor for the automatic lights. That's why it tells you not to cover it up in the owners manual. Seeing as how the temp. sensor measures the outside air temp. it's got to be somewhere outside the cabin you would think.
The temp sensor should be located in that sensor. My wife's Infiniti QX4 also has an outside air temp display, and the sensor is located in the same place on the dash (give/take 6 inches). And the QX4 does not have any light sensor due to not having DRLs.
i know exactly where it is
looking at the front of the car, behind the left or passenger front headlight on the wall behind it you will see a plug and a small attachment plugged on it and that is it.
how do i know?
in putting in the new foglights, i disconnected it to see if that was a cover and was for the fog lights and found out it was the temp sensor
you can reach it from the tire well
how do i know?
