Time for a smoke test - P0171 issue
Old 12-30-2022 | 02:10 PM
  #41
Bonez's Avatar
Originally Posted by BERNS
Replaced the solenoid but when blowing through it, one side will allow to blow through and the other it won't. Checked it with another one and it was the same. My old one was the same way. Are they not supposed to allow air from both ends?
I know it is running rich cause I can smell it when it is running so it is pumping more fuel than normal. Gets to a point that I can't stand the smell and have to shut off after testing for a few mins.
if it is cold out you will smell it rich until it warms up, make sure it is at operationg temps when testing anything.
Old 12-30-2022 | 06:46 PM
  #42
The reason it is rich is because a lot of unmetered air or a shortage of burned gasses is getting to the #1 O2 sensor, making the computer think it is lean so adding fuel to the A/F.
Old 12-31-2022 | 01:33 AM
  #43
Bonez's Avatar
True but also the cat isnt operating yet either.....
Old 12-31-2022 | 08:28 AM
  #44
Little Hhr's Avatar
Just in case you need a cheaper way to go.
Just as an example. I actually have 9 Hhr's at my location
Rberry3000
06-22-2022 12:48 PM
hotwireflyer
Drivetrain (Excluding Engine)
10-25-2019 05:34 PM
Mrdjc
08-06-2016 02:16 AM
donbrew
01-26-2014 07:45 PM
bad03xtreme
05-07-2012 03:38 PM
