timing belt
Sigh - there is no timing belt - it has a chain.
Sorry - second reference today to "timing belt". Me bad.
There is no specified maintenance for the timing chain, however a few owners with high mileage have had problems with the tensioners and chain guides. A kit is available to replace the tensioners and guides from your GM dealer - if you have "high mileage" give your dealer a call for a quote.
Oh, and you can download an Owners Manual from here: https://www.chevyhhr.net/forums/gene...s-manual-3074/
here a view of the timing chain and sprockets
00 11 GM 2 0L 2 2L 2 4L Engine Timing Chain KIT Balance Shaft SET Water Pump L61 | eBay
