Timing belt or chain?
Old 04-08-2009 | 11:18 AM
wagoneer's Avatar
So does the HHR have a timing belt or Chain?
Old 04-08-2009 | 11:21 AM
pitbull76's Avatar
chain
Old 04-08-2009 | 11:23 AM
wagoneer's Avatar
How often do you have to service it?
Old 04-08-2009 | 11:32 AM
pitbull76's Avatar
you don't. Timing chains usually last the life of the engine and do not need to be changed. Read the manual and I'm pretty sure it isn't mentioned to ever change it.
Old 04-08-2009 | 11:34 AM
wagoneer's Avatar
Thanks
Old 04-08-2009 | 12:22 PM
09 Panel's Avatar
I'm guessing that we have an interference engine though, right?
Old 04-08-2009 | 02:16 PM
masterchief1112's Avatar
interference engines use a rubber timing belt.
Old 04-08-2009 | 02:19 PM
09 Panel's Avatar
Nope not true
My sports cars are non-interference and use a rubber timing belt.
My Subaru is interference and uses a rubber timing belt.
What the timing belt/chain is made from has nothing to do with if it's interference or not.
Old 04-08-2009 | 03:09 PM
HipHotRod's Avatar
There are two types of engines that use timing belts. They are described as: "Interference Engines" and "Non-interference Engines" The difference lies in the proximity between the valves and the pistons. On an interference engine, if the timing belt slips even one notch, the piston can crash into an open valve causing serious engine damage by bending valves and breaking pistons. Non-interference engines will usually not self destruct, but in either case if the belt fails, the engine will immediately shut down leaving you stranded.
Let me be a part of the "Chain Gang" anyday.
Old 04-08-2009 | 03:19 PM
09 Panel's Avatar
Chains break too with the same result if you have a interference engine.
Again the question is are our engines interference??
